Hi Guy's, as the title says, I have a fault code & was wondering if anyone could point me in the right direction?
Many thanks in advance
U0421 is an invalid data received from the suspension ride height control module fault, there shouldn't be an R in the code though. The -81 will tell you what, like implausible signal, short to ground, short to battery etc. I don't know what the 81 code is, -94 is implausible signal.
