1 - 10 of 10 Posts
Hi everyone
I have recently fitted a new tailgate to my Rangie but am unable to work out the central locking actuator on it. I have two springs - one long one on the rod that preloads the shaft and another ring type one that baffles me ! It must do something because the system doesn't work very well without it.
Does anyone have a picture of the setup on theirs ? Any advice ?
Adam
FOUNDING MEMBER
A recent similar question got essentially no useful answers. The manuals also seem to be not much help. I keep hoping someone will post a how-to article on this as I need to do mine, as well!
Hi - I've been lurking here for a couple of months, but this is my first post.
I've had the same problem, and been hoping to find photos showing how to attach the springs, but no luck.
so - after a fair bit of trial and error, I think I have it working correctly (i.e. locking & unlocking with the remote).
I had two things to resolve: first picture shows how I attached the circular spring. photo is taken from what would be below the mechanism with tailgate shut (but photo was taken with tailgate open).
[attachment=1:2wtk6run]tailgate-actuator.jpg[/attachment:2wtk6run]
2nd problem I had is that the plunger rod had pulled through the white plastic lever on the lock, so I had to solder a washer onto the plunger at the right place to stop it pulling through now. soldered on washer is sort of highlighted in red.
[attachment=0:2wtk6run]retainer.jpg[/attachment:2wtk6run]
I've had the same issues. I'll try to assemble mine per your pic, and will reply with my findings. I've just left it off for 2 years now lol!
FOUNDING MEMBER
It's been several years since I replace my upper tailgate glass and done without the central locking on the tailgate (without the 3rd brake lamp, too) so will look forward to sorting this out (after I fix my broken rear axle).
Any trick to getting the white plastic holder of the rod and spring to reattach?? I'm guessing they would not sell just that part?? as it looks a bit cracked at the bottom. It snaps over the rod in the base of the frame?
Any help is greatly appreciated.
-Ryan
That part is obsolete, part number is mxc1391 if you want to do a search. Are you asking how to get the springs and everything put back together?
Old thread but I have the same problem. I am not clear on what the other side the the white plastic piece is engaged to. The white plastic piece has a hole for connecting to something (see attached pic), but I can't figure it out.
1 - 10 of 10 Posts
