Hi, I have consulted the Rave manual and searched this forum and I can't find instructions on how to remove the upper rear hatch interior side trim pieces. I can find instructions for the upper and lower trim pieces, but not for the side pieces for the 2004 L322.
Does anyone know how to remove them? I assume there are clips but which way do I pull - towards the front of the vehicle or towards the opposite side? I can't tell and if I pull the wrong way I'm sure to break something.
Thank you.
BTW, I'm taking them off to paint while I replace the headliner this weekend.
Towards the front, and slightly up. You need to remove the upper trim first, and it's easier with the lower trim removed as well.
Be careful with the upper trim, the tabs for the clips like to break off, and have a selection of replacement clips available to you, in case you find a couple broken ones.
Thank you for the help - I was able to remove without breaking any clips.
