The one with the torx bolts on either side. I had no problem separating the control arms using a ball joint split, or removing the lower ball joint, The upper with arm separated seems to be a real problem. No access to get a press over it really unless there is some specialized tool I'm unaware of. Also even with a press it has those wings the torx bolts pass through. How are you guys removing those? I heated it to the point it was glowing, hammered on it with extensions + 5lbs hammer, chiseled under the one wing I had access to, no joy. I'm going to try to find a low profile c-clamp, throw a jack under the rotor, and possibly put the c-clamp over the ball joint and coupled to the jack but I'm not hopefully on that. Any info/tactics/tool recommendation would be greatly appreciated.
TIA
~Brad
TIA
~Brad
