the rubber seal between the dash and the windscreen likes to sink down on the passenger side every now and then. it's just getting old and sun-baked. it's not a crisis but fixing it isn't going to hurt. ordinary i just use a paper clip bent to an "L" shape to lift it back into place until the next time it sinks a little. my dash isn't warped or anything. has anyone looked at upgrading to a slightly larger rubber piece to lay in there in the name of a better/snugger fit? it seems very doable. most of the posts i've found deal with the outside sealing and the issues unique to the finishers. thanks in advance.
yes i've looked through rave. all i find is the windscreen finishers top and bottom left and right. didn't see it in fascia et al. either. :think:
i'm just surprised i didn't see a thread here on it. i can't be the only one who thought they'd like to beef up the in-cabin sound and vibration threshold.
I recently replaced my dash and glued this piece to the new one with some rubber adhesive. Hopefully it holds for awhile, if not, Ill see what lowes has to fix it.
Max you're the man! That's the exact piece I was referring to. :clap:
