2010-2012 Range Rover Sport
I’ve been thinking about getting a set of aftermarktet crank and supercharger pulleys. Found a set on eurotoys and looks like it can do quite a bit in terms of responsiveness and HP/Torque, especially with the ECU tune. Has anyone used their stuff and any regrets? Since the crank and supercharger pulleys are larger and smaller, respectively, the super charger is spinning at a much faster rate, does that exceed its max RPM? Any issues with over heating?
I am actually surprised there isn't more on intercooler upgrade options out there. Ill be following this.
I just got the Evans waterless coolant and although it doesn’t technically cool better than water, with it having a higher boiling point and harder to build pressure I’m assuming it will help the intercoolers with wear and tear. Is my assumption inaccurate?
2013-2015 Range Rover Sport
Evans is glycol based, so it is essentially the coolant already in use, just without water. As for wear and tear, with no water, the internals should suffer no corrosion.
No mods other than the two pulleys and ECU tune. I've been running it for 2 years now with no related issues.
Discussion Starter · #8 ·
Awesome, glad to hear that. I think I’m going to schedule an appointment to take my truck there within the next month or so.
