Ello,
Was wondering if it is possible to upgrade the grill from a 08 to 12 and what is the process?
Many thanks!
Check out this thread: http://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/134586-front-grille.html
Horse86 is correct: It does require front end conversion to have a true '12 grille, however there is a grille available that's similar to the 10+ models without completing the conversion.
If you do a grille swap, it's super easy. Few bolts and a couple tabs that secure it. There's a couple YouTube videos available to help you swap.
