I checked Atl. British, but not sure about plugs and wires.
1) Is there a "better" spark plug for my 2001 P38?
2) Where do I find them, and where do I find "better" spark plug wire kits?
THANKS
Magnecor Spark plug wires, last longer than LR factory wires, and deal with the underhood temp on the the LR V8 .
One of the few "uncontested" upgrades, at least here in the US
http://www.magnecor.com/magnecor1/main.htm
I had a set on my GEMS for 140k miles and just installed a new set on my 01 Bosch RR.
Ordered from.
http://www.apexperformance.net/prod-1155.htm ($100 aprox)
As for spark plugs on the Bosch engine, too early to recommend them but I have installed Champion Iridium plugs, would have preferred the NGK Iridiums but finding them locally was problematic.
The Rovers aluminum heads and awkward angels especially with advanced EVAP (remove secondary air pump), makes it easy to cross the spark plug threads if you are using anything but your fingers when installing, taking a close look at the angle of the plug helps.
I use a touch of anti-seize on the plugs and chase the threads before hand, make sure your hands are clean when handling the plugs and torque carefully.
