does anyone know if there is a reason that an under hood fuse box from a 96 would not work on a 2002? it looks like from pictures that the main Positive lead from the batt is different but thats not a problem as i can swap that over. Is there a difference inside or maybe different relays that are/aren't there?
G
Looking at RAVE a lot of the fuses are numbered differently between the GEMS and Bosch fuse boxes. I wouldn't even try it as there's no telling what sort of problems it would cause.
RIP Our Friend
The actual fuseboxes have different part numbers for GEMS and Bosche. I'd stil with the real deal. Check out autopartswarehouse.com. THey were the cheapest I found when I replaced mine.
theres at least two different GEMS fuse boxes. The Bosch box is completely different and not compatible at all.
