So I went to Sears to buy a new lift/jackstands that they had on sale and the "service engine" light started blinking. I has been on for a while but got concerned when it started blinking. Then it overheated. I know that I was not low on radiator fluid as I keep a pretty good eye on that one. Steam was coming out of the right side of the engine but I could not tell from where. Appears that there was radiator fluid everywhere. Once the steam stopped, I topped off the radiator fluid and off to the autoparts store. They reset the codes but the "service engine" light came back on part way home. In the ten minutes it took to drive home, the light started flashing and there was more steam coming out of the engine compartment once parked.
They said that I had the following errors:
P0300 Randum Multiple cylinder misfire
P0306 Cylinder 6 misfire
P0440 EVAP Emmision control system malfunction
P0304 (times two) Cylinder 4 misfire
and
P1319 (times two) manufacturer controol ignition systme or misfire
Could someone please help with the root of the problem? How are these tied to the overheating or are they even tied to the overheating? Possible solutions?
Thank you! :crybaby2:
and
