did several searches but can't find any info specific to replacing u joints-I'm 1000 miles from home w/o rave manual and mine is making the chirping noise & mild vibrating from the front-( it's been greased) part is available at napa but need to know if this is a machine or drive shop repair or can it be done in with a basic tool kit? looks like it just held in with clips
cheers
peter
if you use that napa part, be prepared to replace it soon
the clips are holding it in, but the caps are pressed in, any shop with a press or even a table vise should be able to do it
RIP Our Friend
? :roll:
I put long stem fitting NAPAs on a buddies P38 2 years ago and it's still going strong. Now NAPA deos have two models, long and short stem. I chose the long stem for easier greasing.
If you have a C clamp and needle nose in your road kit/emergency kit you could easily do this on the road. If not any garage will be able to replace them. Then again I drove a couple hundred miles around the Bay area and then all the way to Seattle with a failed UJ before replacing. It's not something I would recommend, but you should easily be able to get to a different shop if needed.
thanks guys- bought a grease gun at autozone and re greased front to back- then went on a long test drive (half and hour)
no more noise or vibration some old grease was pushed out with this latest effort- no slop could be felt in any of the joints, caps are in place - is it possible that it just needed more lube? I'd think that if the joint is toast it would be noisy and vibrate after a long test drive at highway speed new grease or not?
cheers
peter
Ok - here's how it ended- limped Emma to the next town over (after the vibration and squeaking started again) with a Napa store and a service station in northwest Texas.... Bought 2 top of the line u joints (PUJ 344 in stock believe it or not for $60,) limped to the service station, bought them lunch they backed the owners lifted off road (baja 500 capable no doubt) f350 4x4 that made Emma look like a suzuki samurai off their alignment lift, jacked /blocked up the front axel hand turned the shaft and the rear ujoint about fell out... we removed the shaft, installed the new joints, re-installed the shaft and they charged me another 60.00 and a promise to go the high school football game that evening... not a bad trade off. Made it home with a smooth as silk ride.
