Need to bottom out the set of winter wheels and thanks to all responses ................. understand the issue of hard vs soft compounds and accepting my budget is TINY I'm aiming to buy a set of 16" alloys and need confirmation 215mm wide tyres will fit ~~ my basic maths tells me 215 is in real money 8 3/4 inches wide - std 16In alloys are I believe are 8" wide so should not be an issue but most searches are telling me 235mm / 9.5in wide rims are the required fitment - ALL I need is to triple check is 215 tyres will fit std 16in alloys
If the rim is too wide, the flex point moves towards the rim area, causing heat buildup in the lower sidewall, which reduces tire life and could result in failure.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Range Rovers Forum
