My dealer gave me a diagnostic code following a problem where a 'suspension fault' warning was popping up on the screen on my 2007 Vogue TDV8.
The code brought up a Technical Service Bulletin that describes a simple procedure of changing the exhaust valve on the air compressor inside the assembly, and listed a couple of part numbers, plus the fitting procedure.
I have mislaid this and for the life of me cannot find it online again.
Does anyone have a link where I can download the relevant Land Rover Technical Bulletin?
I have tried registering on that site, but perhaps it is because I am not in the US or UK, it doesnt seem to work.
Thing is, the dealer gave me the error code, which I googled and the first thing that popped up was this TSB, but he has mislaid it and I didnt copy it before giving it to him, and my search history doesnt seem to have it either.
If anyone has a copy in pdf format I will very much appreciate your posting it.
This is exactly the issue, when I had the error code, Google brought up the TSB straight away. Short of paying the dealer to do another diagnostic I cant get the error code.
What I do know though is that the problem it describes is a block exhaust valve on the EAS compressor, and it shows changing a small conical item on the side of it, plus some sort of air dryer assembly.
The car once again is a 2007 TDV8 Vogue SE.
