I am using the eas unlock suite and I want to recalibrate it so that the standard height is the high profile height so it's like a free lift. But when i input the offroad mode settings into the standard profile it just goes into fault mode and displays 255 on each setting. Is there a way to recalibrate it? What does the "high mode on" "transport mode" do on the eas unlock software?
Shupack knows best, but from what i understand, each setting has limits that you cannot exceed. I believe you can reach those settings in high profile, but not in standard height.
In the instructions for EAS unlock it lists this as the max ranges so it should work.
---------------Front------Rear
Extended-- 120-180---105-150
Standard---95-150-----85-130
Low--------75-140------75-120
Access-----50-110------50-100
