For the second time I have used a trickle charger on my 2010 and ended up with a bad battery? Are these models susceptible to this? Are these models hard on batteries? It’s just three or four years old.
I’m using a name brand “Battery Tender” connected directly to the battery.
I’ve used these chargers other cars without issue.
Any insight would be appreciated.
Ed
That's a strange one. My 2010 L322 spends most of its time in my garage plugged into a trickle charger, it's been like that for the past 18 months and to date I have had no issues what so ever. I use a Banner trickle chargers.
Does the car suffer at all with voltage drain when not connected?
I’ve checked for abnormal parasitic draw and it’s fine. Good to hear your feedback. Could be I was just unlucky with those two batteries.
Which battery tender? I've been using CkRT on my cars for years, and my L322 is on one right now, never had a problem.
2016-2018 Range Rover Sport
I use a CTek which will shut off voltage when the battery is fully charged. Some chargers put out a continuous 2 amps regardless of battery condition which can over charge it and boil the fluid out. It also has a a "recondition" mode that's supposed to help batteries last longer.
2019 Velar L560
FWIW, the official JLR trickle charger is a CTEK unit and I can confirm that cycles to a reconditioning mode when the battery is full.
