Weird things been happening with my 04 RR. Transmission started making whining noises, like a serpentine belt, then a Trans Failsafe warning, then an Trans Overheat warning. Had it towed home. Though it might be fluid related, so my plan was to drain the fluid, but on opening the fill hole to check the level, fluid came pouring out. Black, and a little burnt smelling. I drained the rest, but must have been two liters from the fill hole, and about three from the drain plug. Any ideas why the fluid level would be so high, as to come out with such force from the filler hole?
I refilled with the correct amount, but the transmission just wont engage properly. Barely moves in any gear. I'm thinking this is bad! It has 91,000 KM, and I've had it for six months, with no previous problems.
