21 - 22 of 22 Posts
Range Rover MkIII / L322. 2011 SC 5.0 😁
Hi RR876,
That's why I'm baffled, but they think it could be affecting the the signal to the ECU causing an imbalance. As they keep showing up as faulty I'll replace them and see what happens.
I'm sort of convinced that sensors or ECU is playing a part in this as the temperatures are all in within limits on the live data.
Diagnostic's showed no other faults
Pls keep us informed if the fault disappears?
What temp is the oil doing during driving? Because the system can say that all in the range, while during towing all is within the temp range but living on the edge. That is killing for you box.
Discussion Starter #22
Will do Meet,
Sensors arrived today but won't be fitted for a week or so then I'll test it. If it persists I've found a company outside London that has RR diagnostics gear so my plan is to run it over there and have a full diagnosis.
21 - 22 of 22 Posts
