2006 RR 160k miles
Two weeks ago I changed out the transmission pan and also put a new o'ring on the sleeve because it was leaking. Since then I've been having some issues. It's never the same but here they are-
Go to start the RR and it won't start, I have to put it in neutral.
Start it but is rough putting into R or D, if this happens then it doesn't shift just stays in one gear.
Start it and everything is normal and trans shifts perfectly
I know it's going to be ok because when I put the key in and turn it(not even to on) I can see the P sign on the menu. Then it shifts and I can see R and D when it changes. If I don't see that then I know once I put it into drive it's not going to shift. I'm not sure where to start but it seems to be electrical. It seems to be random no matter what it's doing.
Thanks for any help,
Rob
Rob
