Hi, I have been having an intermittent problem over the past few months with my 2006 4.2 Range Rover L322 Supercharged with the ZF 6HP26 Transmission. The car has around 147,500 miles on it, with the original transmission. I first noticed this fault in April, so 4 months ago. The first time the P0705 fault happened I hit a manhole cover that jarred the car around a bit and it threw the car into fault mode. After this first incident, I had no trouble for a month or so and then slowly the fault has occurred more often. Now if I drive the car 2 miles it will go into fault mode. It is completely random when it goes into fault mode. I have been parked, sitting at a light, slowly accelerating, or flooring it and it has gone into fault mode in all different instances, but not every time. It seems to have no pattern as to when it happens.
When it's in fault mode, the indicator on the dash disappears and it slams the car into 3rd gear only. I then have no control over which gear I am in as the shifter does not do anything at this point. I can shift into P, R, N, and D but it slams into gear when doing so. The shifter light next to the shift knob is still illuminated when this happens. I have also noticed that my reverse lights now flicker and do not stay on the whole time while I am in reverse anymore. I switched them to LED's over a year ago. I don't know if this has anything to do with the P0705 but I have read about issues with the reverse lights with the P0705 fault.
I took the car to the dealership and they quoted nearly $10,000 for a complete transmission swap. I think this is absolutely ridiculous as my transmission seems perfectly fine other than the transmission fault issue. I am now thinking about doing this job myself. Would it be possible to clean the contacts on the mechatronics unit and fix the issue that way? Or would I be better off replacing the mechatronics unit? I have read that the mechatronics unit has to be recoded to the car/transmission if replacing. Would I be able to take it to the dealership and have them recode it after replacing or can I recode it myself? Also if you have successfully solved this fault can you give a parts list as to what I will need to order to do this job? If I can fix the mechatronics unit I would also assume I'd be smart to change out the solenoids and all of the seals while I am inside the transmission/working on the valve body.
I would like to know if anybody has any insight into this problem or if anyone has experienced this fault code before on this transmission and fixed it successfully. Any help would be greatly appreciated.
