So i have another issue after i change my transmission fluid. The first time i changed it i changed out the connector sleeve too but there was a small piece of Oring in there so it would not seat right. i found this by using a mini cam to look into the connector on the tranny side. This fixed my Bus communication issues. now after i changed the fluid the first time every thing was smooth even my 1st to 2nd shifts. The second time i changed the fluid to fix the connector issue the 1st to 2nd was crazy. It would feel like it was downshifting right before it shifted up but be fine for the day. The next day it would start and when you put it in reverse would go right to transmission fault. The codes do not come up under OBD code reading. It only comes up using the my icarsoft and only in the land rover auto gear box section. P0736 is what comes up sometimes p0730 and p0741. From what i read the torque converter solenoid needs to be replaced. I wanted to check to see if this was the case and if the other symptoms pointed to anything else and also ask if i should be replacing all of the other solenoids too?
