Hello ! When i start the engine up or when i just put the contact key in, it shows no DRPN green lights on the dashboard and i have Transmision Fail message in the dashboard. The car is moving forward and R -reverse without problems but when i put it in D, the car seems to start from a higher gear, not from the first gear. When i switch off the ignition key and then back on the message dissapier and the gearbox works fine again. I did change all the oil from the gearbox and filter too and the transmission failure message is still there.
