NEWBIE
Join: about 1 hour ago
36 minutes ago · #1
Transsmision controling module fault RR SPORT 2006
Hi have some problem with sport rr, 2006 y, 2700ccm. All lights lightning, also HDC program not available, transsmision fault, engine, suspension.... In range rover service i changed key, braking pedal switch and gearbox selector switch.... But problem is still on... Now they told me that transmission controling module is not ok and he make problems.... Please help me... I found on web used TCM module but im not sure if this is possible to change so easy.... I got error specified on list U102-87IPC...i think this is the part wich is making me problems, attached in picture, also there are few models of this module im sure wich one is ryt one...and where this module is located in car Pls for help... Thank You in advance
NEWBIE
36 minutes ago · #1
P0700 points to a fault in the transmission control system - it doesn't necessarily mean that the control module is bad, just that some part of the management system is faulty.
P1706 points to faulty transmission range/neutral safety switch. This is the switch that determines which position your gear lever is in. A fault with it often makes the gear display blink like yours Nox Vidmate VLC .
