Hey all,
Just had the wonderful experience of finding oil leaking out from the rubber plug on the trans. Confirmed that oil is coming from the transmission side. Guessing its the transmission front seal. Going to pull the trans and replace the seal, but never want to pull the trans again so am wondering what else I should replace 'while in there'.
- Trans input shaft seal
- engine rear main seal
- Transmission sleeve?
- Seals on t-case?
- Rear transmission seal?
- Etc?
Thanks for the support.
2010-2012 Range Rover Sport
I would do the Atlantic British transmission 2-piece metal pan conversion, as well as a mechatronic seal kit.
