1 - 1 of 1 Posts
So I've started getting the Trans Failsafe Prog warning and I had it checked out and it came back that the cause was the Transfer Case Shift Motor. It's very intermittent. I can go for a week with no error message and then have it happen 3 times in one day. I realize from reading other posts that this is not an uncommon problem and I will probably have to replace that part. What I am really wondering is whether I should do a road trip this weekend to go skiing (400 miles roundtrip). I don't want to get stuck somewhere but, as I said, so far it hasn't really caused a problem, just slight hesitation/shift (assume it shifts into 4th) and then right back to normal. Just turned 80K. Thanks for any advice.
1 - 1 of 1 Posts
