Hi,
Today I got trans failsafe prog in my 2003 Range Rover 4.4 when I got up to motorway speeds. It reset upon restarting the car but again appeared after driving above 50mph for around a minute. One time it went into 4th (I think), and and one time I just got the messages but no limp mode. Each time it happened I got the message around 3 times with a few seconds delay between each message. Later in the day I also got another trans failsafe message with the key in position 2 but the engine wasn't started.
I'm planning to change the gearbox oil later in the week.
I read the codes with my OBD2 reader but only got a code relating the engine (P0443 - Evaporative Emission Control System Purge Control Valve Circuit). Can you actually read the gearbox faults with a generic OBD2 reader or do I need to take it to have the codes read somewhere with the right equipment/purchase All Comms/something? I searched on the forums but couldn't find anyone mentioning if you could or not.
Thanks.
Banned
Unfortunately you can not check the transmission codes with the standard obd2 you will need a factory specific tool like autologic or t4
Forgot to update this thread. Turns out it was the transfer box shift motor causing it to go into limp mode.
Banned
Yes if you have a output speed sensor fault logged in the transmission ecu and your sensor is good this is being triggered by the tbox shift motor
