Our 2006 RR L322 drives great in 1st 2nd and 3rd then it bangs trying to go into 4th. Goes back to 3rd and goes into limp mode. We have rebuilt the transmission new valvebody old tcm. We have reflashed the transmission. But still no success still slipping anyone have any ideas??
It does sound like an issue with the E-clutch. I suggest that you remove the Mechatronic unit again and apply air pressure to the E-clutch port to see if you can detect a leak.
Phil
Discussion Starter · #6 ·
I've done that it does sound like there's a sight leak so I replaced the bushing again. And still the same sight air. Do you think possible the whole drum is bad?
That is great news.
What was the problem, how did you narrow it down and what was the solution?
This information will aide others in the future.
