2016-2018 Range Rover Sport
Hi,
I am looking at your IIDTool BT and it says that 2016 L494 is supported. I also found in the FAQ a note regarding the trailer settings. I plan to add a trailer hitch and would like to activate the trailer camera feature that is normally included when you buy the OEM towing package. I asked the dealer if they could activate it and they can but I want to know if the IIDTool BT has the same capability?
Thanks...
Hi
If the required hardware is fitted, you will be able to enable this feature called Trailer stability assist.
Hi
Thank you Patrick. Is the same true for the "Advanced Tow Assist"? Assume the 2020 RRS Sport has the required vision assist and driver assist cameras installed and the OEM hitch and electrics installed by the dealer post-sale.
