1 - 10 of 10 Posts
I have a 2010 RR autobiography and was going to get a boat. Do these have trailer brake controllers built in or do i have to install one? I haul a small bike trailer now but it is just the lights and it works but I would need a brake controller for boat?
I'm not an expert but I think it depends on what size boat you plan on trailering. If it's a smaller boat and the weight of everything is under 3000 pounds then trailer brakes aren't really required. If more than that you might consider getting a trailer with hydraulic surge brakes. I had a 27 foot keel boat that weighed over three tons and the trailer had hydraulic surge brakes.
with electric brakes and a brake controller you have a little more control over when the brakes are applied which can make it safer if the load starts swaying.
Anybody know if i got the standard brake controller that mounts under dash, is there a plug in for it? Or has to be custom wired? Was looking at the Bluetooth one that plugs into the 7 pin connector but i like being able to reach down and use trailer to slow me down.
Discussion Starter · #6 ·
Well got it all setup and trailer lights work but no brakes. I am getting power to the connector, not Sure yet how many volts tho. Controller says n.c when you turn lever.
I recommend the Tekonsha wireless brake contriller. I pull 6000 lb gross Airstream and it works great; saves doing a dash rettofit.
Discussion Starter · #8 ·
Did some multi meter work today. I get power to the 3 and 9 oclock pins when i use turn signals and brakes, I also get power there when i put manual lever on tekonsha but there is no power at the 5 oclock pin which I read is the trailer brake pin but wierd cause my 7 in to 4 pin adapter doesnt even have a pin there. I looked and all the fuses seem to be in in passenger side fuse pan2elo and rear fuse panel. Don't know where to look now.
Like colobound, I too use a Tekonsha wireless brake controller. No need to mess with under-hood or under-dash wiring. You might check the thread "2003 RR HSE Towing Experiences."
It’s very easy to wire on a 2010. They come prewired. You need the Tekonsha P3, and a ford adapter plug. Plugs right in under dash. I believe I made a post about it. Then if you have the big hitch receiver and 7 pin connector already installed, you’re good to go. Don’t mess with wireless in this case, too easy to hard wire it.
here..
https://www.rangerovers.net/forum/6...eed-trailer-brake-controller.html#post1638497
1 - 10 of 10 Posts
