TPMS Question
795 Views 3 Replies 3 Participants Last post by  kg74
Does anyone know what kind of TPMSs works On a 2006 Range Rover SC and where the best deal is to find them? I would be ok with used ones even if I can find some.
From what I understand they are all interchangeable as long as the frequencies match the vehicle.
If that is correct, why are some $200 each and others $25?
And do they need to be programmed or just installed?
Thanks in advance !
They are 315Mhz units and as long as they are 315 Mhz any TPMS sensor will work. The RR ones actually have ford part numbers printed on them.
Thanks for confirming that.
That is a $300 saving tip!
Maybe you get lucky and can find a used wheel with working TPMS. Worth a shot.
