TPMS fuse location?
86 Views 1 Reply 2 Participants Last post by  NorCal RR
I’ve got a 2009 L322 and my low tire pressure warning is going on my dash but my tire pressure has been checked and it’s correct, so I’m thinking of disabling the TPMS rather than replacing a sensor. Can someone tell me which fuse and location I need to remove.
You owners manual has a fuse chart in it. But removing the fuse is not going to solve your problem. Probably the cheapest, easiest solution will be to replace the sensor and while you are at it, replace all four.
