Did you have to remove the tow cover to access the brake controller plug?
Great! Thanks for the tip! now I know what to look for when I need to tow.The wiring plug manually is rotated down into position when you want to plug into your trailer harness. When done towing, just push (rotate) the plug back up into the space behind the rear valence trim. Very stealthy design and well built.
