THis is one of those items I always go to a Rover suplier for. Give the folks at Atlantic British a call with the paint code under the hood. One is for paint pen the second is for spray. They are only a few bucks each.
LIRA said:Same here regards the touch up pens, they actually made the scratch on my wing look worse. The only way to do it successfully is rub it down with 600 grit paper, prime and spray on the colour getting a good blend. Use a good clear coat on top of that. The preperation is the key to a good finish.
The hardest colours to match are the pearlesant ones like Epsom Green etc, the genuine LR touch up spray cans are good or go to a local paint supplier with your colour code, Epsom Green is 961 for example, a good quality clear coat makes all the difference too
