1 - 13 of 13 Posts
Hey guys Im looking for some opinions on the best tire size for 22" wheels. Any input will be appreciated. Thanks .
285/35/22 is what I had when I was on 22s.
i had 285/35 on my first couple of sets (22x10 rim) and just went with a 265/35 last time round. honestly, the ride has been just as good if not better and the price is definitely a lot more friendlier. I purchased a set of pirelli scorpion zero assimetricos for approx $750 shipped.
you can check out a couple recent pics in the gallery.
FYI, the width on the wheels now are 22x9.5
Discussion Starter #10
Those wheels are awesome!
I think I want a little more sidewall though, seattle is tough on the wheels you know. I'm guessing that it will be significantly more expensive though .
285-40-22 is the largest tire that will fit without rubbing in all modes.
Pics all over the forum, I have the Falken Ziex
The larger sidewall makes the car look slammed in access mode. I like them alot, I would have been sad if I went with 285-35-22's...
265-35-22 would be narrow-er than I have now and shorter...
OE 20" size is a 275/40/20
22" size with roughly the same as factory diameter is 295/30/22
You can go to 285/35/22 with slight speedo error and thicker sidewall but no rubbing or other adverse effects.
The 285/40/22 will physcially fit, but it is quite a bit oversize from the OE tire which = a lot of speedo error..personally, I wouldn't go this route myself, but that being said, it should still fit.
1 - 13 of 13 Posts
