OK, so here is the background. At 23,000 mi i put on a new full set of tires. I put on OEM tires (Conti Contact UHP). then at 38,000 mi I had really bad tire wear on the two fronts inside was totally worn. So i put on two new OEM tires. now at 47,000 mi i need two more (rear). So i don't have any options other than two more OEM tires. so here are three questions:
Can you put on two tires that are not the same as the other two? probably not advisable.
Where would you put the new ones, in the front or rear?
Is it normal to only get 23,000 miles out of a set of tires, AND I DRIVE 90% HWY, NEVER IN THE CITY>
thanks for any input!
LP
I'll offer my experience, although I can't really answer your questions. I replaced my stock contis somewhere in the neighborhood of 25k miles, and I probably could have gone another 1k or so if I wanted, but why risk it? If they are wearing unevenly, I would look into what is causing it, might be in need of some adjustments, and you might consider rotating them periodically to prevent it from happening in the future. Good luck
