My light is constantly on and off randomly, a few seconds here and there. I would actually prefer to disengage it if I could! I need a little help! Thanks
Forgive me for asking the obvious question, but have you checked your tire pressures?
What year is your RRS? I 'think' the pre-2010 facelift cars can be programmed with the IIDTool to turn off the TPMS
Tire pressure would be the first culprit to look for. Check the pressure on all 4 corners and compare to OEM. +/- 10 lbs and you will get a light.
Also, the TPMS sensors in your tires operate off of a battery. When the power in that battery wanes, it can no longer reply to the system query and you will receive a light indicating there is a problem with the TPMS.
