rrtoadhall said:
:shock: Our sunroofs are already mirror tinted and UV protecting. If you are doing it for looks, it will make no change on the outside due to the mirror tinting already in place from the factory. If you want it to be even darker inside, just close the sunshade.
Doing it for looks!!! Like who's ever going to look at the sunroof :lol: Mine has that speckled stuff through it but it doesn't do that much. I like the open feeling of having the blind back but when you live in a country which has no ozone then it'd be good to darken it a bit.
Col said:
The film will not Bond to the Glass Properly due to the Glass having a Textured Effect instead of Smooth Surface and will peel off
Thanks for that, just the kind of info I was after.
THe texture can be removed from the glass with a blade to install new tinting if you are strictly after a darker look from the inside. You can also remove the glass panel very easily and clean the snot out of it and use spray tinting. Again, there will be no difference from the outside, only on the inside. Frankly I think you are nuts, but then again folks think I am nuts for having stickers on my rig. :mrgreen:
