Hi there,
I´ve looked around but couldn´t find. Has anyone out there a list with the timken (or other alternative brand) bearing and seal numbers? Thank you!
Any particular bearing and seal or all of them?
Right now I´d need for the wheel hubs. But I would be very grateful if you could share a list for all of them (in case you have it)
I guess many fellows here would benefit from that.
For me the point is that here in Brasil I can find almost all LR replacements I want but very very expensive. Even items such as bearings and seals that are generic. They sell it as "LR part" almost 5 times the regular price.
So if I had that list, I´d be saving big :D
best regards,
I can't help with hub seal numbers but I should have the bearings out in the garage. I'll check.
Inner / outer bearings are LM603011 race, LM603049 bearing
I recommend converting the bearings to oil-lubricated rather than greased.
See this topic for more info: http://www.aulro.com/afvb/good-oil/5551 ... -rest.html
Discussion Starter · #6 ·
Dear Ron,
Only now I could see your reply. Tks a lot for the codes and the info on the convertion!
best regards from Brasil,
