Phil,
Should the car be warmed up and cycled through the gears before i drain it? I did not see anything in RAVE about warming it up-
THX
If your in a relatively warm climate, it shouldn't matter much. I'd only warm it up if you were in a cold place.
In fact, you'll probably drain more quicker if you have left it untouched for a while as all fluid will pool at the bottom in the sump. Having it running will have pushed it all about into the nooks and crannies.
