For those of you who want to play.
1. Does the P 38 headlight switch light up?
2. If it does, where is the light bulb?
3. If you decide it has a light bulb how do you get to it?
This is only a test :lol:
well of course it does... when it works
the microbulb is in the base unit of the switch
you get to it via a 6pak and a great friend... or remove the cluster trim to get to the 5th screw for the switch panel after romoving the radio facia then pulling the switch panel and pulling the lamp switch and pulling the micro from the base unit.
Ok will it appears that no one else wants to play, Carl you have won 25% off your next order! CONGRATS :clap: :clap:
In the last two weeks I have replaced all dash lights in the Rangi,I have upgraded to the Green cluster and green clock If any one is interested in this info let me know and I will do a complete write up with pic's, on the process..
I'm interested. I feel abby normal on the weekend when I have no leaks to fix.
Mine never lit up
FOUNDING MEMBER
I'm interested in photos of this!
