1 - 17 of 17 Posts
On our 1500 mile return from picking up our new (to us) 2007 Rover, something was baffling us. As you know, when you start to drive, the locks automatically lock, great. But, when we come to a stop, we pull the door handle once to unlock the door, and the second pull opens it. That's odd, but something we can live with. But what is completely baffling us, is that once we exit the vehicle, we find that neither of the rear doors are unlocked. Which means we either need to depress the button on the key, or hop back in the truck, and hit the central unlock button. Now, I've owned a lot of cars, and never have I owned one that operated like this. I assumed this had to be a setting somewhere, so I consulted my owner's manual, but it doesn't really address that issue. So, I came on here and searched, because I can't be the only one dumbfounded by the logic. I couldn't find anything with my search.
So, if this isn't a setting and it's working as designed, that means if I have a child in the back, my procedure to get myself and my child out of the truck would be:
1. Turn off ignition
2. Pull door handle once to unlock
3. Pull handle a second time to open driver's door
4. Pull on rear door and remember that the truck doesn't unlock when driver's door is unlocked
5. Cuss and mumble under my breath
6. (a) Open driver's door, hop back in the truck, and hit central unlock button or (b) pull key out of my pocket and hit the unlock button 2 times
7. Remove child.
Or, I could just remember to hit the central unlock button every time I shut the truck off. Now, I know that is the easy thing to do, but after 22 years of driving, and never having to do that, it may take some time to become habit.
So, my ultimate question is, is there a way to set it up so when the driver's door is unlocked, that all doors unlock?
G
Guest
There maybe an option to set the doors to unlock as soon as the key is removed, but this is an option that can only be switched on/off by the dealer. Not all cars have the auto lock when you start to drive (as yours does). Again, this is another dealer switched option.
The rationale? If your wife were to approach her car, unlock the door and get in, someone hiding on the other side of the car (unseen) can't jump in the car because all doors but the drivers door will still be locked.
2019-2021 Range Rover Sport
All Land Rovers seem to operate this way. This is why we disabled the automatic locking "feature" on our past few Land Rovers. If they don't automatically lock, then you don't have to worry about unlocking them before you get your child out of the back.
That's the way they work. Instead of using the "pull the handle twice" method, I try to always hit the central button whenever there are other people in the car. It's a new habit...
I don't know if this works on all Range Rovers, but it seems to work on my 2007 HSE:
To disable autolock, get out of the car, shut the door, insert key into lock on driver's door, turn key in the "unlock" direction (right?) three times in succession. That seemed to disable my autolock feature, but I'd gotten used to the autolock and turned it back on again (by turning the key three times in the "lock" direction).
RRDave said:
Yes. That's how they work.
Kinda Dumb, don't you think?
Definitely an interesting design, that's for sure.
Right. Most late model vehicles work like this. Or are at least configurable to this logic. You're describing unlocking the vehicle from outside, before you depart. But I'm talking about all doors unlocking from inside the truck, after the driver door is either (a) opened, or (b) the vehicle is put in Park/Shut off.
Silly design.
Certainly an option, not sure if we're willing to delete the auto-lock feature, just yet.
Since mine is a 2007 as well, I'll give it a shot. Thanks for the nugget.
Requiring two pulls of the handle to open a locked door from the inside is a BMW feature across their product line that was carried over to the MkIII along with a lot of other BMW commonalities. Those of us that came from BMW's think nothing of it, I can see as a Mercedes man that it would seem odd. It's not a Land Rover thing. The feature where rear doors require a second push of the unlock button can be disabled by the dealer in wy wife's 06, in my 2010 I can disable it from within an option menu. Not sure about the 07s.
Funny thing is my wife's previous car, a Volvo XC70, allowed the doors to be opened from the first pull, but the new Volvo XC60 needs two pulls, just like the Range. At least it (still) automatically locks the doors after a passenger gets out.
G
Guest
Silly design.
Nope, I'm talking about both. Yours has the auto lock when you reach xxMPH configured to on, so your doors are locked when you complete your journey. Ergo, if you press the main central locking button below your hazard lights all the doors magically open, right?
Now if you don't have the auto lock feature switched on and reach your destination, the drivers door will still be unlocked (assuming you are the only passenger) and the other 3 doors will still be locked. If you use the central locking button (below the hazard switch) it does not unlock the remaining 3 doors as you would expect, but instead locks the drivers door. To unlock all door, you would have to press the central locking button twice. Just something to think about before you de-activate the auto locking feature.
This is why the door handle unlocks the respective door after the first pull and opens it on the second. With the previous model (P38a) either of the 2 front door ledge buttons would activate all 4 doors central locking (open and closed).
Discussion Starter #14
BenzORama said:
[quote="Mr. Range Rover":5uunfb0w]
Silly design.
This is why the door handle unlocks the respective door after the first pull and opens it on the second. With the previous model (P38a) either of the 2 front door ledge buttons would activate all 4 doors central locking (open and closed).[/quote:5uunfb0w]
Got it.
It certainly appears that we'll just have to get in the habit of hitting the central unlock button every time we're toting passengers around in the backseats.
Ya know, this is another area where the domestic American cars get it right. My wife's 97 Olds locks the doors when she puts it in gear. When she puts it in park, they unlock. My other domestic cars unlocked AND opened with a single pull. None of this "what if someone wants to unlock the door, but not actually get out" sort of silly logic. :think:
So many design features of these europen vehicles just don't seem to make sense for the majority of drivers.
you will get used to it, though its kind of annoying esp when your passengers are trying to figure out how to open the door...if you forget to hit the central unlock..
In theory, it should make it a little harder for someone to car-jack you. If you get someone on the street suddenly pulling a gun and trying to open your door, you may be able to escape before they either shoot you or smash the window and open the door by reaching inside and pulling *twice* on the handle. But, depending on where you drive, this may be such a remote possibility that you'd rather disable the feature.
I still try to be aware of my surroundings and avoid bad areas. I certainly locked my doors manually one time when I exited the highway in a rather sketchy part of DC (I never suspected to find bars on windows and bullet proof glass on the gas stations/drive thru windows in a spot so close to the national mall, etc) I was nearly out of gas but I hastily added 2 gallons and sped away when car loads of suspicious people appeared, got out and started approaching me rather directly .
1 - 17 of 17 Posts
