After my turbo and fuel pump problems it seems that my nav screen does not now want to work. When I start up the screen stays blank. When I checked out the fuse (which was OK) I noticed that when I re-inserted it the nav screen came on and was OK for the rest of the day's motoring but was again dead the next day. I wonder if there is a bad connection at the rear of the fuse box or the screen.
Has anyone released the fuse box or screen and how easy is it to do??
Any ideas anyone?
try eject and reinsert the cd from the navigation.
My sat/nav stopped working, ejected the cd and reinserted it, has worked well since
I think you misunderstand the problem.
Nothing works! the screen itself will not turn on unless I remove and re-insert the fuse(49). When I do this the screen powers up fine and all associated things work OK (say nav, venture cam, CD, radio ETC) but only after I remove and re-insert the fuse.
