· Premium Member
Hey Guys,
Working on our new addition to the family, son's 95 LWB soft dash Classic. Replacing the viscous coupling. Emptied the transfer case of it's oil, to get started, and out comes a nice golden thick oil. Slightly thicker than engine oil, about the same color. :shock:
Was expecting ATF. Any advice or experience with this? All specs say ATF, that I could find... :think:
· Premium Member
Yeah, finished the viscous replacement and refilled with Mobil 1 ATF. What should have been in there to begin with... :roll:
Oh well, we'll see how the t-case runs now. Can't imagine it would cause any problem.
This is strange.
I am going through my 89 doing a baseline service, all oil's and fluids etc.
My Hayne's manual specifies a 90w oil for the Borg Warner viscous transfercase, which is consistant with what you drained by the sounds of it.
It specifies ATF for the LT230 T.Case, and also ATF for the LT77
Very interested to know if its a cock up in the haynes manual or not before I go put the 90w in (lucky as was going to do this last night !!!!!!)
Pete.
90w might be a tad thick... but
Interesting timing. I just had an interesting exchange of emails with the technical department of Penrite Oil Company.
To make a long story short, when I took delivery of my '93 LWB it had a seized viscous coupling. *&^$%, anyway, after dropping $900 bucks for a new part I was trying to do the best thing and came across a Penrite spec sheet. I put in 75(SAE75-80) manual gear oil in. Later, after I noticed my manuals suggested AFT Dex II, I panicked. How would affect my new VC? HO NO!!!!
This is what the Penrite tech told me today:
"The manufacturer suggests that the same fluid used in the automatic transmission may be used in the transfer case (a Dexron II ATF).
Whilst this is the case, we have found that Manual Gear Oil 75 (SAE 75W-80) gives better performance, hence it is our recommendation."
I think the '95 RRC factory manual suggests 75w-80 instead of ATF. Maybe they finally figured it out. The transfer case has a pump in it, but then again it has a chain too.
· Premium Member
Discussion Starter · #8 ·
My RAVE for 95 says, "ATF Dexron IID". Oh well... it's probably not critical. But it is interesting that such different fluids can replace each other. :geek:
