2015 Range Rover L405 Supercharged & 2006-2009 Range Rover MkIII / L322
My thermostat housing on my 2006 range rover hse 4.4 cracked while replacing the coolant sensor. Can anyone give me a write up of how to remove it? I have the new one in hand.
Same procedure as the 2007 4.4. It will be covered in the 2007-10 shop manual that has a link in the FAQ stickie above.
2006 Range Rover L322
I had a coolant explosion in my truck after driving it for 14 hours at 75mph, and at low speeds it overheats when the heater is on. I had to drive through a Canada nasty winter with no heater, and I an now stuck here out west near British Columbia with no heat. Broke down a few times in the middle of nowhere, but i go it sorted an now I want to permanently fix the issue before I head back. which shop manual are you referencing? I want to replace the thermostat and flush the coolant system.
Thanks!
