Noticed that as well. The triple front nozzles use a lot of fluid, but they work well.
Have you noticed how much overspray hits the cars behind you? Probably get flipped off every third time I hit the spray button.
Sent from my SM-N960U using Tapatalk
2019-2021 Range Rover Sport
Hey guys and girls, so has anyone noticed that they are going through an absurdly large amount of windshield fluid? Like a bottle every 2-3 weeks? I got a 2019 RRS, do they just use way more fluid when cleaning then I am used too?
Funny that you just posted this, it was just today that low fluid level came on and i just filled to the top and could not have used it more than 15 times since filling. It does spray a ton of fluid not only onto the window but also if you have your lights on it soaks them as well I just didn't realize just how much it was using.
Those headlight washer hoses leak sometimes too. Or the pumps...
Also I'm pretty sure the tank is vented to atmosphere which with a volatile fluid like alcohol isn't that great either.
