As you all know by now, VelocityAP was kind enough to extend a limited time group buy to the members which ended May 10th 2018.
This thread serves to host all the Q/A regarding the tuning process and results.
Please be as thorough as possible with any information you add to help those who might be stuck in the process. I'll add the first bit about how the process has worked for me so far:
- I ordered as part of the group buy. My car is a 2016 SVR (5.0L SC). Item was shipped promptly as promised with instructions and packaged really well.
- In the instructions there was a link to download a piece of software which I downloaded (.exe file) and installed on a Windows 10 (Lenovo T470) with no issues. The software does several downloads and updates when you first load it and attached it to the device. No errors were encountered.
- I noticed in the software and later in the device that the 5.0L RRS is not part of the list. Stuart responded to my inquiry immediately that I can use the option for the 5.0L Range Rover Fullsize (BOTSCH MED 17.8.31).
- The instructions call for an external power source for stability but I believe most of us have skipped that step so far. I skipped it too.
- Once connected to the car and followed the instructions, the only thing a bit confusing was the it asks you for the "key on" or similar message, and that's when you're supposed to actually click the start button once. A few minutes later, after the dash lights went off and on several times and several faults were shown I got a message that indicated I was done. I then disconnected the device and connected back to my PC and saved the file to my PC which by default has a .usr extension. It's a binary file in case you were thinking of opening it `) . Mine was 106KB.
- I have now emailed the file to Velocity and am awaiting my tune to arrive. However, it's important to note that this morning, my Check Engine light was on. I restarted the car about 6 times with some pause in between and the fault has gone away since. Car is operating normal as of right now.
- I will continue to document my experience. I also have some videos which I'll have to edit. So far the customer service has been very responsive and the device seems okay and the PC software is stable.
