I don't know if it's Just me or that's normal, so every time when I stepped on the brake pedal I will hear a sound squeaks that really annoying me if I turn off the audio when it's quiet. it's not the sound from the brake pad on the wheels from outside of the car. It's the sound that came from inside the brake pedal I step on. Don't know if anyone understands lol or maybe it's just me
SUPER MODERATOR
I've had this issue with several cars. The pivot point at the pedal just needs a shot of lube. I use white lithium grease in a spry can as it doesn't dry out or gum up.
RRtoadHall, can you tell me where do I spay it to? Do u think wd40 will work?
SUPER MODERATOR
You spray it on the pivot.
WD-40 is not a lubricant, it is a water displacement. What little lubrication it provides will quickly deteriorate.
I have had issues with mine and LR replaced the entire assembly, there is a known service bulletin out on it. However, it still creaks so maybe lube would work.
