Hello all
Range rover p38 4.6 GEMS 1996
Can anyone help and know the correct length of the single flanged bolt which holds the fan belt tensioner to the alternator bracket
Took the tensioner off and some cowboy had fitted an helicoil in the bracket, which came out with the bolt.
Panic at first, as thought it stripped the threads out of the head or timing case cover, then realised it was a separate bracket holding the alternator on.
Found an m10 high tensil bolt, of longer length which luckily caught the last remaining threads in the housing as a temp repair
Have found an second hand housing, and although the original bolt threads are in good condition, to me it does not come threw the other side of the tensioner that much, so not sure if someone has fitted the correct one in the past
Thanks hopefully someone has a parts catalogue
Super Moderator
M10 x 75mm, part number FB110151L
