2013-2015 Range Rover Sport
Hello friends lately I have changed the water pump on range rover supercharge sport 2014. After changing the water pump I have poured the premix solution coolent 50/50 into the radiator, after 10 minutes the engine got so much hot, I have switched the car off and drained some of the solution and then added some water then started the car and drove for 60 kilo meter of distance and the temperature now in the middle , I do not know what happened in the begging, dose anybody run into this situation before.
Thank you
ahm
RIP Our Friend
You most likely just had an air pocket from not bleeding the cooling system fully. No harm, no foul. If it is staying in the middle it sounds like you got the last of the air out. :thumb:
