Found the filters...Oil is still an issue....Even the Castrol site changed the recommended oil to their Magnatec vs the Edge... both are Full Synthetic...yet a good 5W20 Full Synthetic for light duty diesel with DPF you should be in pretty good shape...esp every 5-6K miles...
Sounds great,
Problem I find is that YOU CANNOT RESET the maintenance Message. I had to take to the Dealer, and was told that the process taught to "open hood,, open door, etc"...to reset will not work, as Dealer can only reset through a special tool. I did try several times to reset, I do get a message that service is reset, but once I restart, message is there and engine light is on...
Any thoughts?
Thank you
LCL
Hmmm.... it is strange. I did reset it several times already on my 2016 TD6 and it worked, but I have not got any messages that it was reset. Any dealer will tell you that it can not be done..that's where they make money I'm using the below steps to do it :
§Turn the ignition key to position “ON” without starting the engine, If your Range Rover has push-button start, press the “Start” button without touching the brake pedal. §Open the hood and the drivers door §Hold the accelerator and brake pedals all the way down for 10 seconds §SERVICE RESETTING will display in the dash §Turn off your car and start the engine to see if warning went away.
Related Threads
Range Rovers Forum
834.2K posts
121.9K members
Since 2004
