P0171 bank 1 too lean
P0174 bank 2 too lean
P0734 Gear 4 incorrect ratio
My online research says MAF. What say you?
Discussion Starter #2
Well now I've cleared the codes and the now the incorrect gear ratio is gone but there's a o2 sensor code.
You could always put a multimeter on the MAF output and see if the voltage is approximately 1.4v at idle, and see if it changes proportionally with a steady change in rpm.
2005 Vogue 4.4
I could also be an intake ducting, or intake manifold leak.
I cleaned everything between the maf and the throttle body and was pretty diligent about seating the seals. But it could be a myriad of other points i suppose.
Clean your MAF sensor with a MAF sensor cleaner first.
You probably need a temper proof torx bit to remove the sensor from the housing.
